[?]: Siwarex WP321 FB code
mow_neo
Post by mow_neo »
Hi all
Does anyone have the source code for the official WP321 Function block from Siemens?
I am pretty sure it's SCL (it usually is) and I would like to make a simpler / more streamlined FB.
If not, I can also use an overview of what the I/O 16 bytes are used for, if anybody knows
The block is for the ET200SP Tech-module of the same name: 7MH4138-6AA00-0BA0 / SIWAREX WP321
The (locked) block can be found inside several projects here:
https://support.industry.siemens.com/cs ... 0&lc=en-US
Thx in advance (thnx)
Re: [?]: Siwarex WP321 FB code
STL from Step7 v5
use S7canOpener for unprotect Step7 v5 function viewtopic.php?f=1&t=19796&p=60807#p60807
mow_neo
Post by mow_neo »
Thank you for the answer, the Helium tool worked for me :)
I am not a huge fan (nor any good really) when it comes to STL/IL but it is interesting to see.
If anyone ever acquires some code in SCL/ST then I would like to see that as well.
(tyou)
