I have an old system that was changed from communicating over profibus to use the TCP/IP network connection. This works fine but brings a license popup every ten minutes or so.
The message is Caution: you do not have a license. Softnet-PG IE Windows 98, NT 4.0 Order #: 6GK1704-1PW30-3AA0
I think I need a extra license file, possibly A9SNEX90
I have tried playing with Sim_EKb on a seperate windows 10 machine but I cant seem to create a yellow disk image successfully.
This is running in a VMware virtual machine so if someone has a yellow disk image I can attach that directly to the VM.
So hopefully someone out there can point me in the right direction to get this resolved.
Thanks,
[?+]: WinCC R4.02 Windows NT - Yellow Disk Image
antsrealm
Re: WinCC R4.02 Windows NT - Yellow Disk Image
Softnet A9SNEX90.IMA
https://mega.nz/file/6eogVbBZ#KE0f2Buey ... IE_cCdmxTU
Yellow floppy disks are activated by formatting one of the 70 tracks
Жёлтые дискеты активирутся форматированием одной из 70-х дорожек
https://mega.nz/file/6eogVbBZ#KE0f2BueyTpz0AbkRPmoOhALOrKGDjN4MIE_cCdmxTUЖёлтые дискеты активирутся форматированием одной из 70-х дорожек
antsrealm
Thanks CoMod.
That image came up with an error see below. Also can you explain the process of creating the yellow disk to me. Whenever I try to do it I get a write error. Basically I start with winimage and create a blank image. Then I use the EKB tool to write the yellow disk to that image but it always fails with a write error.
Link to screen shot below.
you use real floppy ? or Image for virtual drive ?
Impossible to create "Siemens bad tracks" for virtuale floppy drive
Sim_EKB_2006_11_14a.zip
https://mega.nz/file/PCoHSQib#9pYpVBZZE ... Z44FmrxjKA
For NT try Siemens.exe from old keyset
https://mega.nz/file/PCoHSQib#9pYpVBZZEbXvKFhphLRX-YNQsHaXal7HUZ44FmrxjKA-
antsrealm
Yeah virtual floppy on Vmware workstation pro.
That Sim_EKB_2006_11_14a software was what I needed.
Ran that SiemensEng.exe on the NT VM and added the license I needed.
Test environment looks good. I think this is a winner.
Will confirm in a weeks time.
Really appreciate the help with this old stuff.
Machine will be decommissioned in the near future so wasn't worth a full upgrade.
antsrealm
Re: [?+]: WinCC R4.02 Windows NT - Yellow Disk Image
Yep that worked great. Thanks again.
