Dears
do you have backup parameter file for siemens MM440 for ZT55VSD from atlas copco Air compressor and which program and tools are used ?
						SIemens MM440 of atlas copco
				claudio2169
Re: SIemens MM440 of atlas copco
For program  use converter USB/485 Seneca S107USB other converters MOXA, ROLINE,ETC...doesn't work.
To connect port on pin USS PORT (pin 29- 30 for micromaster 440) in this plug on your ATLAS COMPRESOR we have connection cable to HMI
Software to program SIEMENS DRIVE MONITOR or STARTER.
https://www.seneca.it/linee-di-prodotto ... b/s107usb/
