I am encountering a problem with B& R servo motor drive ACOPOS 1180 . On HMI the alarm appears as "Servo Error" when enable command is given to servo motor in automatic mode and the drive RUN status LED goes off whereas there is no indication on the drive's ERROR LED .
Problem appears sometimes during running but not frequently.
						Servo drive error in B&R ACOPOS 1180
				Abdul Mutalib
