[Topic already exist]: TIA does not recognize licenses
BongoBongo
Post by BongoBongo »
I have an external USB HD SSD with win 10 and I have installed TIA15 SP1 and it happens to me that ALM recognizes the licenses installed with EKB but STEP7 does not and keeps asking me to activate the 21 day license.
I also tried with ver 16 and 17 but it always does the same.
If, on the other hand, I do the same procedure on an internal HD, the problem is not there.
Have you ever had a similar problem?
Thank you
[Topic already exist]: About keys and Sim_EKB_Install
need screencopy of AX NF ZZ folders
and ALM screencopy
(sfaq) How do you deactivate the Trial License when the message appears indicating that the Trial License has expired, although the Floating License has been installed?
(sfaq) https://support.industry.siemens.com/cs ... t/24200966
https://support.industry.siemens.com/cs/document/24200966/how-do-you-deactivate-the-trial-license-when-the-message-appears-indicating-that-the-trial-license-has-expired-although-the-floating-license-has-been-installed-?dti=0&lc=en-WW
add :?: to existed topic "About keys and Sim_EKB_Install - Здесь говорить о ключах"
(sfaq) viewtopic.php?f=30&t=218
