Hi
I do not know here is a good place for this question:
I'm looking for some web stock market in Russia can find some control unit like Siemens CU320 or CU310, Allen Bradley servo drive, or some brands of servo motors in stock.
Anyone here knows some supplier of automation in Russia?
Regards
Paul
need an automation supplier in Russia
Владимир
Re: need an automation supplier in Russia
There are many suppliers and dealers in russia. What exactly do you need? And in which region of Russia? Russia is very big.
Владимир
http://www.centecgroup.ru
https://simatic-market.ru
http://www.simecs.ru
enter the brand name dot ru in the browser
https://www.klinkmann.ru/products/rockwell-automation/
https://industrial.omron.ru/ru/home
and so on
and so on
Paul Serve
Владимир
Thanks a lot.
Actually my contact lives In Moscow, nearer is better. Yes, I know Russia how much big is, and assume there must be a special area where the automation dealings mostly occur, maybe of industrial areas are there or some reason else I don't know. Is that right?
If you know some special supplier in Moscow or other zones with a hanfull of different brands of automation parts, introduce me please
Regards
Thanks a lot.
Regards
Владимир
Unfortunately, I am not a supplier and I am not a dealer. And I do not have detailed information.
There are no special areas in the country, but most of the automation companies are located in Moscow. There are several federal districts in the country and each has its own dealers and distributors. You probably need a central one, where Moscow is.
Коллеги из Москвы, подскажите уже парню, что ему там надо...
Paul Serve
Thanks again
Best wishes
Best wishes
