[?]: download to S7-1200 error
omar zedan
Post by omar zedan »
Dear All
I try to download project to S7 1200 1214C DC/DC/Rly (the CPU without memory card)
But the message Load will not be excuted (The memory card is protected from write access) appare.
I try TIA 15 and TIA 16
The firmware is 4.2
What can I do to solve this problem???
Re: [?]: download to S7-1200 error
If you look inside the memory card slot, there is a little pin way down inside, on the left. It gets pushed in when you put a memory card into the slot, and makes a contact letting the PLC know the card is there. You had to stick a tiny screwdriver in there and pry that pin out to the right a hair. This fixed it.
omar zedan
Dear Sania
I try to find something wrong in memory place but there is nothing wrong.
Thanks friend
The problem still there.
