Dear All,
I am facing a problem in FX2n,
Infact i am making a totalizer from the flow. everything is fine. but client demands to add some totalizer value to start with totalizer.  the problem is that when i add 50000 value the value of registers stucks. although i am using 32bit float register along with DEADD command for Totalizer. the makes some steady at some place. i dont know why. but i give the totalizer 0 it works fine.
Any Solution regarding this will be help.
