Connect Siemens HMI TP1200 Comfort with PC/Laptop
akhmadzaki
Post by akhmadzaki »
I have a Siemens HMI TP1200 Comfort 6AV2 124-0MC01-0AX0 in my machine.
I want to clone the display on the HMI to PC/Laptop.
My question is:
1. What software that I need for this task?
2. What kind of interface that I need between the HMI and PC/Laptop (for example ethernet cable, etc)?
3. Do I need to communicate with PLC connected with HMI or can I just connect with the HMI?
Thanks in advance for the answer.
Re: Connect Siemens HMI TP1200 Comfort with PC/Laptop
1.1. SmartServer, SmartClient option - https://support.industry.siemens.com/cs ... ankingDesc
1.2. need transver key to panel - https://support.industry.siemens.com/cs ... t/27005215
2. 3. You can use only 1 Panel-PLC-PC interface: Profibus OR Profinet
Swissi
Post by Swissi »
Hi
Please can you help me
I have tp1200 comfort and need to connect to pc to watch machine status on pc.
Just need showing same hmi display.
Project was made by tia portal v13, and I can't contact with machine manufacturer to get original project file.
How to activate smartserver?
Really appreciate your help
Regards
