dear alll
We want to have a spare CPU s7 400 with the program that whenever the CPU has a problem, we can install it quickly without the need to download program . Is this possible ?
We put the spare CPU in the rack and downloaded the program, But when we cpu out of the rack and re-installed it, the CPU entered stop mode.
[?] s7400 cpu
kambiz
[?] s7400 cpu
kambiz
Re: ? s7400 cpu
CPU with EEPROM card ? yes
Diagnostic buffer of module CPU 412-5 H PN/DP
https://s17.picofile.com/d/8419772600/5 ... gnose1.txt
https://s17.picofile.com/file/841979560 ... avian_.jpg
Diagnostic buffer:
Order No./ Description Component Version
6ES7 412-5HK06-0AB0 Hardware 1
- - - Firmware V 6.0.3
Boot Loader Firmware expansion V 6.0.0
Rack: ---
Slot: ---
Serial number: SVPD9763259
Settings:
Time including CPU/local time difference (0 h)
Event 1 of 6: Event ID 16# 49A4
STOP: inconsistency in the configuration data
occurred when checking Parameters for internal consistency
No consistency entries assignable
Error type: Time stamps of the loaded parameter fields do not match
Previous operating mode: STOP (internal)
Requested operating mode: STOP (internal)
Event occurred in the master CPU in rack 0
External error, Incoming event
12:01:34.486 AM 01/01/1994
(Coding: 16# 49A4 F844 C17B 0004 0000 0131)
Event 2 of 6: Event ID 16# 530D
New startup information in STOP mode
Startup prevented by:
Loading user program or internal inconsistency detected
(SDBs less than 200 incomplete, superfluous, or incorrect)
- Cold restart or warm restart necessary
Startup information:
- Time for time stamp at the last non backed up power on
- Single processor operation
Current/last startup type:
- No startup type/following memory reset
Permissibility of certain startup types:
- Manual warm restart permitted
- Automatic warm restart permitted
Last valid operation or setting of automatic startup type at power on:
- Automatic warm restart after non backed up power on (with system memory reset)
Operating mode: STOP (internal)
Incoming event
(Coding: 16# 530D F804 C777 0140 0000 7720)
Event 3 of 6: Event ID 16# 530D
Incoming event
12:01:34.479 AM 01/01/1994
(Coding: 16# 530D F804 C777 0040 0000 7720)
Event 4 of 6: Event ID 16# 43F1
Switchover of master CPU and standby CPU
Previous operating mode: STOP (own initialization)
Requested operating mode: STOP (own initialization)
Incoming event
12:01:33.346 AM 01/01/1994
(Coding: 16# 43F1 F833 0000 0000 0000 0000)
Event 5 of 6: Event ID 16# 430E
Memory reset executed
Initialization information: Memory reset due to inconsistent data
Previous operating mode: STOP (memory reset)
Event occurred in the standby CPU in rack 0
Incoming event
12:01:28.498 AM 01/01/1994
(Coding: 16# 430E F023 CE00 0000 0000 0008)
Event 6 of 6: Event ID 16# 4309
Memory reset started automatically (power on not backed up )
No relevance for user (Z1): 0001
Previous operating mode: No voltage
Requested operating mode: STOP (memory reset)
Incoming event
12:01:28.479 AM 01/01/1994
(Coding: 16# 4309 F0F2 CE50 0001 0000 0008)https://s17.picofile.com/file/841979560 ... avian_.jpg
Re: ? s7400 cpu
