[?]: TIA portal 15.1 installation error
Charismatic
Post by Charismatic »
So I've been having trouble installing TIA Portal v15.1.
During the installation, I always get an error message saying "some installed products need licenses".
I'm on win 10 Pro 64 bit.
The log file can be found here: http://txt.do/1eusu
18:56:51 |ERROR    AdsWorkerForeignExe::GetInstallResult():  - -2146498512: assuming unknown error, because return value is not in OK-list which is only defined. Please check the corresponding log file for more detailed information
18:56:51 | FAIL!                     SetupUnit                  (MSMQ_Activation_Workstation)Failed    Foreign   AddLocal
18:56:55 | OK                        SetupUnit                  (DotNet_Updater)            Complete  Foreign   AddLocal
18:56:55 | FAIL!                     Checkpoint                 (RE)                        Complete
18:56:55 |ERROR    ExecutionEngine::StartNextStepAsync():  - Execution has been cancelled. Probably because of some process(es) running on the machine
Thanks for your help in advance. Been struggling for a while now.
Here is an image of the error: https://i.stack.imgur.com/t1C5t.png
Re: [?]: TIA portal 15.1 installation error
Close "some process(es) running on the machine"
https://social.msdn.microsoft.com/Forum ... ?forum=wcf
Install IIS and MSMQ "Microsoft Message Queuing"
Run setup by Admin
Charismatic
so i tried to enable msmq but i got another error, go figure. error code 0x800F0830
Charismatic wrote: Tue Nov 17, 2020 5:30 pm so i tried to enable msmq but i got another error, go figure. error code 0x800F0830
try TIA v16
