how to use GX Works 2 accessing Mitsubishi PLC via GOT1000
другие контроллеры
jianxin0820
Post by jianxin0820 »
I have tried many time to use GX Works 2 to access PLC via GOT1000 but failed. Can guide me how to do the communication connection.....
What I have done:
I have found the IP Address of PLC module. 192.168.3.39
Transfer setup connection
1. PC side I/F Serial Setting
 ・ Select [USB].
2. PLC side I/F Detailed Setting of GOT
 ・ CPU mode: Select [QCPU (Q mode)].
 ・ Select [via GOT(Ethernet) transparent mode].
    ・ Model: Select [Ethernet Built-in CPU].
    ・ IP address: 192.168.3.39
3. Other Station Setting
 ・ Select [No Specification].
