Hello, Please I need to understand the following network
Please refer to ATV71 programming manual cap. 1.9 (COM-) &
atv71_parameters_en_v3.xls
[Scan. IN2 address]= 8604 (RFRD ->Output velocity - 1=1 rpm)
[Scan. IN3 address]= 3205 (OTR ->Motor torque - 1=0.1% of rated torque)
[Scan. IN4 address]= 3204 (LCR ->Motor current - 1=0.1 A)
L PIW [AR1,P#2.0] //[Scan. IN3 address]=
T #Drive_Speed
L PIW [AR1,P#4.0]
T #Drive_Torque
L PIW [AR1,P#6.0]
T #Drive_Current
[?]: Profibus altivar 312 VFD and S7 300
[?]: S7-Altivar71 Profibus read code
L PIW 264 // StatusWord
L PIW 266 // 264 +2 [AR1,P#2.0] //[Scan. IN3 address]=
T #Drive_Speed
L PIW 268 // 264 +4 [AR1,P#4.0]
T #Drive_Torque
L PIW 270 // 264 +6 [AR1,P#6.0]
T #Drive_Current
Melad
Re: [?]: S7-Altivar71 Profibus read code
hello, thank you very much for your help
kindly I have more questions:-
1- Why not written directly PIW270, and written like this PIW [AR1,P#6.0]? I think it is easier and more clear...
2- Why PIW270 refers to drive current and PIW268 refers to torque?
3- What are the related parameters of the Altivar drive and how to setup?
4- Please explain the following:
Thank you
Thank you
Melad
Kindly, I need sample program "simatic manager" to control an altivar 312 VFD by S7 300 PLC through profibus protocol
Start/Stop, Speed control, read speed and current.
Please do not consider this as a repeated topic
Rex2701
