[Request]: WinCC IDB Industrial Data Bridge 7.5 /w SP1, sharing IDB 7.5 sp1 and request 7.4 sp1 version
xflash
Post by xflash »
Hello~
I have got a WinCC IDB Industrial Data Bridge 7.5 SP1, it could be used with WinCC 7.5 sp1, I think it is latest verison (2020/11), I uploaded it to mega:
https://mega.nz/file/FFhWCJLS#iy8F13WVN74I1e0u7iqdU5inMFK5hlVp98lOZk9dFK0
iso file hash
CRC32: F735A345
MD5: 23500DC47D12AB3657D18D29D6A44EDD
SHA-1: 2BFA6111A98111C545E0B008E208C35297591A21
SHA-256: 1E04414169E6C8B995B544B000CD6968568237C8F49CAF82434814283D9362F9
But I have two kindly requests:
Please update ekb for IDB 7.5, latest is IDB 7.4, not working for 7.5... New key function does not work...
But So sorry, for 7.5 key SIFCYA9IDB99997 (V99.99) working, not that hurry any more.
Please upload WinCC IDB Industrial Data Bridge 7.4 SP1 if you have the image, I could only download 7.4 (without sp1) version from rutracker. What I provided 7.5 sp1 version will NOT work on Windows 7, so we need 7.4 sp1 version....
Thank you all!
xflash
[?+]: WinCC IDB Industrial Data Bridge 7.5 /w SP1
Post by xflash »
So sorry,
key SIFCYA9IDB99997 (V99.99) working for 7.5,
arthur_floriano
Re: WinCC IDB Industrial Data Bridge 7.5 /w SP1, sharing IDB 7.5 sp1 and request 7.4 sp1 version
Post by arthur_floriano »
I'm having some problems during the installation of IDB 7.5 SP1, the log file says:
14:45:44 |ERROR    AdsWorkerForeignExe::GetInstallResult():
- 1638: assuming unknown error, because return value is not in OK-list which is only defined.
Please check the corresponding log file for more detailed information
14:45:44 | FAIL!                     SetupUnit                  (VC_2015_REDIST_X86)        Failed    Foreign   AddLocal
14:45:45 |ERROR    AdsWorkerForeignExe::GetInstallResult():
14:45:45 | FAIL!                     SetupUnit                  (VC_2015_REDIST_X64)
Can anyone help me, please?
xflash
Post by xflash »
I am sharing same error messages. I think it is OK it is just visual C++ redistribute packs. My software works without an error.
xflash
Post by xflash »
EDIT2: key SIFCYA9IDB99997 not working anymore....
ATTENTION - DEMOVERSION
You do not have a valid License.
It's necessary for a continuous operation.
OK
Re: [Request]: WinCC IDB Industrial Data Bridge 7.5 /w SP1, sharing IDB 7.5 sp1 and request 7.4 sp1 version
just reinstall key again
(sfaq) 16.12.2020 Why are licenses of WinCC Runtime Advanced damaged on IPCs?
if an IPC is not shut down properly, the runtime licenses that were previously in use are not released again.
The next time you start the Runtime, these licenses are marked as "defective".
Problem
After starting an IPC with WinCC RT Advanced, a message appears stating that certain licenses are not available.
However, these were installed on the corresponding PC/IPC during commissioning.
In the Automation License Manager (ALM), the required licenses are displayed as available.
However, when checking the corresponding licenses, they are marked as "defective".
When starting the WinCC Runtime Advanced software, the corresponding licenses are allocated.
If the PC is not shut down properly and the RT is terminated correctly, these licenses will not be released.
This may be the case, for example, after a power failure or the abrupt shutdown of the IPC.
The next time the runtime is started, the corresponding license is then considered defective.
Официальное объяснение почему так может произойти (boom)
xflash
Post by xflash »
Not working...
Do you encounter same problem?
need FULL report viewtopic.php?f=4&t=11415 and ScreenCopy
xflash
Post by xflash »
It does not contain IDB info...
Thank you all the same.
ALM Log
01.12.2020 15:07:46   License_Info start -----------------------------------------------------------------------
01.12.2020 15:07:46   ProjectType - WinCC-Standalone
01.12.2020 15:07:47   Project - Operation Mode SCADA RT
01.12.2020 15:07:47   Project - OperationMode Changed from Operation Mode Undefined to Operation Mode SCADA RT
01.12.2020 15:07:47   SUCCESS! (PO and Tag Count Values set to) POs:0 Tags:2294
01.12.2020 15:07:47   --------------------------------------------------------------------------HandleProjectOpened
01.12.2020 15:07:47   Version - 1600
01.12.2020 15:07:47   ProjectPath - \\SERVERCTRL\WinCC_Project_HMI_8VV2_1\HMI_8VV2.mcp
01.12.2020 15:07:47   ProjectState - Open
01.12.2020 15:07:50   USB-Dongle: USBDongleMode Euro
01.12.2020 15:07:50   Dongle - USB-Dongle: USBDongleMode Euro
01.12.2020 15:07:50   + >>>>>>>>> Constructs CLicenseRequest ReqID:1, GroupActiveCount#:1 App:AppRT:Mcp LicenseIDRequested:AppRT:Mcp Holder:KERNELHOLDER Group:AppRT:Mcp
01.12.2020 15:07:50   ActivateGroup-------------------Group:AppRT:Mcp (OK:0, Used:0, Licensed:0 -spam-:0 IsUsed:1 AllowActivateTrial:0)
01.12.2020 15:07:51   License granted in ALM-------------------Group:AppRT:Mcp (OK:0, Used:2294, Licensed:0 -spam-:0 IsUsed:1 AllowActivateTrial:0)
#  License Object: Key:WCRP??1600 Granted:SIFLWCRP021600 Name:WinCC RT Professional Text:WinCC RT Professional (max.) Granted=1, Installed:1
01.12.2020 15:07:51   - >>>>>>>>> Constructed CLicenseRequest ReqID:1
01.12.2020 15:11:23   + <<<<<<<<<< Destruct CLicenseRequest ReqID:1, GroupActiveCount#:0 App:AppRT:Mcp LicenseIDRequested:AppRT:Mcp Holder:KERNELHOLDER Group:AppRT:Mcp
01.12.2020 15:11:23   DeactivateGroup-------------------Group:AppRT:Mcp (OK:1, Used:2294, Licensed:2147483647 -spam-:0 IsUsed:0 AllowActivateTrial:0)
01.12.2020 15:11:23   License freed in ALM-------------------Group:AppRT:Mcp (OK:1, Used:2294, Licensed:2147483647 -spam-:0 IsUsed:0 AllowActivateTrial:0)
01.12.2020 15:11:23   - <<<<<<<<<< Destructed CLicenseRequest ReqID:1
01.12.2020 15:11:24   --------------------------------------------------------------------------HandleProjectClose
01.12.2020 15:11:24   Project - OperationMode Changed from Operation Mode SCADA RT to Operation Mode Undefined
01.12.2020 15:11:24   ProjectState - Closed
01.12.2020 15:11:47   Project - Operation Mode SCADA RT
01.12.2020 15:11:47   Project - OperationMode Changed from Operation Mode Undefined to Operation Mode SCADA RT
01.12.2020 15:13:39   Project - OperationMode Changed from Operation Mode SCADA RT to Operation Mode Undefined
01.12.2020 15:13:39   ProjectType - WinCC-Standalone
01.12.2020 15:13:40   Project - Operation Mode SCADA RT
01.12.2020 15:13:40   Project - OperationMode Changed from Operation Mode Undefined to Operation Mode SCADA RT
01.12.2020 15:13:41   SUCCESS! (PO and Tag Count Values set to) POs:0 Tags:2294
01.12.2020 15:13:41   --------------------------------------------------------------------------HandleProjectOpened
01.12.2020 15:13:41   Version - 1600
01.12.2020 15:13:41   ProjectPath - \\SERVERCTRL\WinCC_Project_HMI_8VV2_1\HMI_8VV2.mcp
01.12.2020 15:13:41   ProjectState - Open
01.12.2020 15:13:46   USB-Dongle: USBDongleMode Euro
01.12.2020 15:13:46   Dongle - USB-Dongle: USBDongleMode Euro
01.12.2020 15:13:46   + >>>>>>>>> Constructs CLicenseRequest ReqID:2, GroupActiveCount#:1 App:AppRT:Mcp LicenseIDRequested:AppRT:Mcp Holder:KERNELHOLDER Group:AppRT:Mcp
01.12.2020 15:13:46   ActivateGroup-------------------Group:AppRT:Mcp (OK:0, Used:0, Licensed:0 -spam-:0 IsUsed:1 AllowActivateTrial:0)
01.12.2020 15:13:46   License granted in ALM-------------------Group:AppRT:Mcp (OK:0, Used:2294, Licensed:0 -spam-:0 IsUsed:1 AllowActivateTrial:0)
01.12.2020 15:13:46   - >>>>>>>>> Constructed CLicenseRequest ReqID:2
01.12.2020 17:27:27   + <<<<<<<<<< Destruct CLicenseRequest ReqID:2, GroupActiveCount#:0 App:AppRT:Mcp LicenseIDRequested:AppRT:Mcp Holder:KERNELHOLDER Group:AppRT:Mcp
01.12.2020 17:27:27   DeactivateGroup-------------------Group:AppRT:Mcp (OK:1, Used:2294, Licensed:2147483647 -spam-:0 IsUsed:0 AllowActivateTrial:0)
01.12.2020 17:27:27   License freed in ALM-------------------Group:AppRT:Mcp (OK:1, Used:2294, Licensed:2147483647 -spam-:0 IsUsed:0 AllowActivateTrial:0)
01.12.2020 17:27:27   - <<<<<<<<<< Destructed CLicenseRequest ReqID:2
01.12.2020 17:27:29   --------------------------------------------------------------------------HandleProjectClose
01.12.2020 17:27:29   Project - OperationMode Changed from Operation Mode SCADA RT to Operation Mode Undefined
01.12.2020 17:27:29   ProjectState - Closed
01.12.2020 17:29:00   Project - Operation Mode SCADA RT
01.12.2020 17:29:00   Project - OperationMode Changed from Operation Mode Undefined to Operation Mode SCADA RT
LicenseLog.xml
:anon: show file C:\Program Files (x86)\SIEMENS\WINCC\diagnose\LicenseLog.xml
mrvoice
Post by mrvoice »
arthur_floriano wrote: Mon Nov 16, 2020 4:55 pm I'm having some problems during the installation of IDB 7.5 SP1, the log file says:
I face the same "errors" problem.
Did you fix it?
Or is it working anyway even with the installation Errors?
