usb-PPI multimaster cable for S7-200
gerido
Post by gerido »
Hello.
I have the USB-PPI multimaster cable 6ES7901-3DB30-0XA0
The db9 connector has broken, someone knows the colors pinout to repair??
Thanks in advanve.
Info
Faq & Info
Faq & Info
Re: usb-PPI multimaster cable for S7-200
Post by Info »
gerido
Post by gerido »
Thanks.
I find this picture but i need to know thw pin number and the colour of the wire (red, green, yellow....)
I don´t know that it is possible.
Thanks a lot
4 colors... but not yellow
http://s7detali.narod.ru/CP5511/USB_PPI.html
USB
gerido
Post by gerido »
thanks.
I need the other side, the d9 connector.
the wires are: red-white brown-black green-yellow
I try to connect to the Plc with other cable amsamotion ppi cable and pc adapter and is not possible Some times appear the plc unknow, and I think that the problem perhaps is the cable.
I need to solder d9 connector
Thanks a lot
