[+?]: PRONETA Professional 1.1 EKB
xflash
Post by xflash »
Greetings!
PRONETA has became PRONETA Professional, it supports record assistant to check profinet devices, it will be very useful for debugging, but it requires a key and in new keys folder there is none.
If someone know to get a key, please share... (thnx) Thanks.
https://support.industry.siemens.com/cs/document/109781284/trial-version-proneta-professional-v1-1-?dti=0&lc=en-WW
EKB-PRONETA
Show
Also a hint:
https://support.industry.siemens.com/cs/ww/en/view/98161300
SIMATIC Automation Tool is 4.0 now, you will need the key in new keys folder.
EKB-Automation Tool
Show
update:
viewtopic.php?f=30&t=218
Sim_EKB_Install_2020_10_10.zip has updated, it has these two sets of above keys. No need new keys folder. :D :D :D
sventek
Re: [Request EKB Update]: PRONETA Professional 1.1
Post by sventek »
I can't see this 8 keys in the "New keys" folder. Is there anything I did wrong?
sventek
xflash
Post by xflash »
My fault, it works when install the service (sorry)
Proneta log
Show
EKB after install Proneta
Show
Proneta work
Show
Hoping helping someone in future.
Best Regards...
aboozar
Re: [+?]: PRONETA Professional 1.1 EKB
Post by aboozar »
None of your images are loaded!
all works
preview
Show
xflash
Post by xflash »
Check your network! (att)
aboozar
Post by aboozar »
Thanks. This post works well. However, I still COULD NOT see "xflash" post (photos were broken) solved: Network settings problem ( (sorry) ).
xflash
Post by xflash »
please get the new ekb:
