S7300 - Problem downloading function FC1 to plc
sawo333
Post by sawo333 »
Hello ,
I need help with solving issue why i´m not able download function FC1 to my plc
Files with errors,screenshoots of networks inside FC1 and text logs are here
https://easyupload.io/rz7cnz
Thanks for every answer
qqwww
Re: S7300 - Problem downloading function FC1 to plc
Post by qqwww »
The program was previously downloaded to another PLC?
If yes your actual PLC 6ES7 315-2EH14-0AB0 has smaller PI.
I don't see a problem with FC1. But with DB273, the problem is written directly in black and white.
And judging by the error, you didn't even manage to compile the written code, but are already trying to download it. Who taught you this?
Answers to FAQs
Faq & Info
Faq & Info
Post by Answers to FAQs »
you are have some problems
1. is using reserved name "nop" inside the temp area ( rename to any another like "nop1")
2. is db273 not loaded into cpu ( right click on the db -> plc-> download)
3. need check if you are have any additional errors...
