Hi guys, I got the following error after installing winccflexible 2008 sp5 in windows 10pro. Someone will know how to solve. Thank you
Éste es un informe de errores creado automáticamente para WinCC flexible Engineering System.
 Professional		6.2.9200.0
Versión del producto: WinCC flexible 2008 SP5 Advanced; V 1.05; V 1.5.0.0 (1.13.03)
Siemens.Simatic.Hmi.Utah.SystemDiagnosis.-spam-
Failed to write version information file: 'C:\Users\glopez\AppData\Roaming\Siemens AG\SIMATIC WinCC flexible 2008\VersionInformation.xml'.
Exception Source
SystemDiagnosis.DiagnosisClasses
Exception Target Site
Void WriteVersionInformation(System.String)
Exception Stack Trace
   en Siemens.Simatic.Hmi.Utah.SystemDiagnosis.VersionInformation.WriteVersionInformation(String versionString)
   en Siemens.Simatic.Hmi.Utah.SystemDiagnosis.VersionInformation.CheckVersionInformation(IContext context)
   en Siemens.Simatic.Hmi.Utah.Framework.AppLoader.Initialize(String[] args, IContextCreatorCallback callback)
   en Siemens.Simatic.Hmi.Utah.Framework.AppLoader.Run(String[] args)
   en Siemens.Simatic.Hmi.Utah.Framework.AppStarter.Main(String[] args)
End Exception
System.UnauthorizedAccess Exception
Acceso denegado a la ruta de acceso 'C:\Users\glopez\AppData\Roaming\Siemens AG\SIMATIC WinCC flexible 2008\VersionInformation.xml'.
Exception Source
mscorlib
Void WinIOError(Int32, System.String)
   en System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   en System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
   en System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
   en System.IO.FileStream..ctor(String path, FileMode mode)
End Exception
