Digital counter display wiring to the output terminal
salman101
Hi, I am using rather an old PLC (FPO-CT32) by Panasonic with FPWINPRO 7. It doesn't give out the option of activating a high-speed counter for the output channels. On the input side (X) I have attached a rotary optical encoder and using the high-speed counter channel as input from the encoder (which is a pulse train). After each complete revolution of the encoder shaft (500 pulses), I want the digital counter to display the count i.e. 1,2,3..and so on. I have developed the logic in the program but how do I use/interface the output channel (Y) with the digital display counter? I am using the basic digital display GDD797949AT (24-28v) with a six-pin connection on the back (2 pins for reset, 2 pins for supply, 1 pin for the up count, and 1 pin for the down count). Thanks
