S7-1200 COMMUNICATION WITH IGNITION SCADA ON MODBUS TCP / IP
surducan365
Hi. Can someone help me tell me how to communicate between scada ignition and s7-1200 on modbus tcp / ip? Do I have to use the Modbus Client function?How do I create the DB with tags? Thank you in advance
longyunlangzi
Re: S7-1200 COMMUNICATION WITH IGNITION SCADA ON MODBUS TCP / IP
You should asking for help from the Ignition.
PLC_ITA
ignition scada have OPC driver to comunicate on 1200 without you need to use modbus tcp
Suggest : change your scada : the better scada on the world for have a lot of problem.
good luck
good luck
