Hi all,
I have PLC Analyser installed in Oracle VM, win7.
When i run the VM with higher than 4Gb Ram the application does not start. (the anawin.exe process starts but ends without exit status 0x0 on event viewer).
Although, if i use less or equal to 4Gb ram, the application starts ok.
As anyone faced the same issue?
PLC Analyser V5.4 Problem on VM
smallandquiet
Re: PLC Analyser V5.4 Problem on VM
Yes. Because the software with this version only can support OS bit 32 like WinXP X86. RAM above 4G is for X64 normally.
wuliang55
Yes. Because the software with this version only can support OS 32 Bit like WinXP X86. RAM above 4G is for X64 normally.
ermohamed07
PLC Analyser driver not loaded error
