I need to connect PLC to unidrive classic with UD71
The inverter use ANSI protocol
I need to change the ANSI protocol to RTU modbus
Do you have program, protocol or instruction to connect using PLC
I can't connect using Delta PLC maybe something error
Thanks in advance
