Experts!
I have a indradrive C HCS02 of type CSB01.1C-SE-ENS-EN1-L1-S-NN-FW (BASIC UNIVERSAL SINGLE AXIS).
All of a sudden the drive can not read encoder memory with C0270 (error in reading encoder memory).
I check the encoder cable, and the motor encoder with other indradrive C, They are all right.
Then find out that the drive problem is just with S1 encoders (SICK SKS36), and the drive can read the S2 type encoder (Heidenhain ECI 1313), No error.
So I thought Maybe the measuring system of the drive is OK.
Is there any chance for eliminating the error by replacing the firmware of Indradrive?
And how can I do it?
Indraworks Ds software has a option for upgrading firmware, But first I should find the firmware file *.ibf extension.
The current firmware version is Mine is FWA-INDRV*-MBP-04V42-D5-1-SNC-NN, and I think it can be upgrade to some FWA-INDRV*-MBP-05VRS-D5-1-SNC-NN.
Any help would be appreciated.
Regards.
Indradrive C
INGCISNEROS
Re: Indradrive C
hi, can you fix it? i have a similar error
