SINAMICS G120 + encoder
привода и частотники
smnt
Post by smnt »
An encoder is installed on the G120 inverter, the readings of which are read by Profinet using Standart telegram 3 PZD-5/9.
How can I reset the encoder from the Profinet?
Where can I read in the documentation on setting the inverter with the encoder via Soft Starter?
Re: SINAMICS G120 + encoder
Повторять посты - дурная привычка.
