[?]: SIMATIC WinCC Runtime Advanced V15.1 in TIA PORTAL
spike_gsi
Post by spike_gsi »
Hi!
I have a S7-1200 PLC with TIA PORTAL V15.1
I installed Simatic WinCC Runtime Advanced V15.1 in TIA PORTAL to use it as HMI.
I have 400 PowerTags aprox, so a 512 PT license would be fine.
HMI WinCC works fine, communicates with PLC, shows values, and so on; but I get a pop-up window very often with the following message in it:
¡License key not available!
WinCC Logging for Runtime Advanced
I must have done something wrong in the keys installation.
Could anyone please help redirecting me to the right procedure for this software and key installation ?
Thank you very much for your help.
Regards,
Spike_gsi
Re: [?]: SIMATIC WinCC Runtime Advanced V15.1 in TIA PORTAL
key for WinCC Runtime Professional< (no) > WinCC Runtime Advanced
see Help
spike_gsi
Post by spike_gsi »
Thanks very much for your fast answer.
So i have to download this SW:
http://www.plcforum.uz.ua/viewtopic.php ... nal#p87058
And then See the 'help' downloaded with those files,
and install 'key for WinCC Runtime Professional'
Am I right?
Thank you very much
Regards,
Spike_gsi
SIFLWCLORT9999 WinCC Logging for RT Advanced
https://support.industry.siemens.com/cs ... t/74796111
(sfaq) What information is available about licenses for WinCC (TIA Portal)?
