Tank level Tag for maximum /minimum
ggg315
Post by ggg315 »
Hi
I am using this bar to indicate the level of the tank on HMI
it has "Tag for maximum" and "Tag for minimum", What am i suppose to connect here ?
I have two sensors one sensor is 0 to 10 VDC another is 4 to 20mA what to connect here ?
https://i.imgur.com/k4sX6ru.jpg
See Scale function
See Scale function
(sfaq) https://support.industry.siemens.com/cs ... t/39334504
For an S7-1200/S7-1500 controller in STEP 7 (TIA Portal), how do you scale integer values in real numbers and vice versa for analog inputs and outputs?
ggg315
Re: Tank level Tag for maximum /minimum
Post by ggg315 »
Thank you
I already SCALED the input to 0 to 100
then can i leave these blank ??????????
or i fill Minimum =0 and Maximum=100 ?????
Answers to FAQs
Faq & Info
Faq & Info
Post by Answers to FAQs »
you can connect any free datablock/memory to these inputs and change them from hmi
