Hi to everyone,
I just got backup of one HMI panel but don't have any idea what application open/load it.
Any ideas about this file type?
What HMI application use *.ctz file extension?
h4rdw4re
ubug-12151
Re: What HMI application use *.ctz file extension?
Citect Scada AVeva
The Vijeo Citect backup program archives project files using the industry standard ZIP compression algorithm. The default file extension for Vijeo Citect backup files is .ctz, though any extension (including .zip) can be used. You can use any utility that supports .zip files to extract project files from a compressed Vijeo Citect backup.
h4rdw4re
Thank you very much.ubug-12151 wrote: Tue Sep 17, 2019 9:26 am Citect Scada AVevaThe Vijeo Citect backup program archives project files using the industry standard ZIP compression algorithm. The default file extension for Vijeo Citect backup files is .ctz, though any extension (including .zip) can be used. You can use any utility that supports .zip files to extract project files from a compressed Vijeo Citect backup.
