[?]: how this SCL block works
ggg315
Post by ggg315 »
Could someone explain me how it works ?
https://docdro.id/e7ZCprT
Re: I need help To understand how this block works
и что конкретно в этой простыне не понятно ?
Comments in Russian understand ?
ggg315
Re: [?]: how this SCL block works
Post by ggg315 »
No. I need help with SCL code .
ggg315 wrote: Mon Sep 09, 2019 6:52 am No. I need help with SCL code .
add :?: in PDF (rr)
pigroplc
Post by pigroplc »
ggg315,
you better deeply study the interface with the motor considered by the code, then later on, you will understand the code.
The code itself has just some IF...THEN and it's quite easy to understand how it works.
your native language ?
In this block comment in Russian - you know Russian ?
Do you know Siemens programming languages LAD/STL/FBD/SCL ?
