asteroidehk
Posts: 109 Joined: Sun Dec 30, 2007 8:03 am
Post
by asteroidehk » Sun Sep 01, 2019 3:57 am
Hello Friends
I am installing a new W7 VM.
I have installed TIA PORTAL V13 SP2 UPD2 and I am trying to installa Scout TIA V4.4 HF11, but a mesage appears: "This product cannot be installed on the current versión of Totally Integrated Automation Portal V13.0 SP2 UP2"
screencopy
https://ibb.co/0JR8NL8
Do I need another version? o which could be the problem?
Thanks in advance.
gabcor
Posts: 19 Joined: Tue Oct 18, 2016 10:02 pm
Post
by gabcor » Sun Sep 01, 2019 8:27 am
asteroidehk
Post
by asteroidehk » Mon Sep 02, 2019 10:44 pm
Hello
So, Is it not possible to install on TIA Portal V13 SP2?
What happend if I install TIA Portal V13 SP1, then Scout 4.4 HF11, Will this work?
But if I install after, SP2, then Scout Will stop working?
Thanks again.
a12sdd
Posts: 5 Joined: Sun Apr 25, 2010 2:22 am
Post
by a12sdd » Thu Feb 04, 2021 8:41 pm
Is a old post but....
Just go directly to the installer
SCOUT_TIA_V4_4_0_11\ScoutTia\CD_1\Start.exe
dont run the root installer
