tp1200+s7 417h
rayen_6827
tp1200+s7 417h
Post by rayen_6827 »
hello
i have a cpu 417H and i want use touch panel tp1200 with profibus dp IN LOCAL FIELD please help me how dos it?
iN local i have remote io ET200M
thanks.
TIA Portal Comfort panel and old Step7 v5.5 PLC
rayen_6827
Re: tp1200+s7 417h
i dont understand and your link is not ok
I have one central control system 400H and 3 numbers of ET200M.
each ET200M is installed in a room and it is necessary to monitor data of each room separately
(one touch panel for each ET200M rack).
how can I connect touch panel to ET200M?
can I use Y-Link and profibus network?
what is the best solution for it?
Re: tp1200+s7 417h
(sfaq) 14.06.2012
How do you connect a panel to a SIMATIC H station?
https://support.industry.siemens.com/cs ... t/23842653
