I installed pcs7 v9 sp1 on windows server 2016 and error 2772:105 in wizard creating os bjects
And installed on windows server 2012r2 then error 2772:105
Please help
On laptop and pc tested
“I don’t see any thing of sql server 2014 in stat menu!!!!”
And I separate install from directory pcs7
[Problem]: Install SIMATIC PCS 7 V9.0 with SP1
rayen_6827
Re: [LINK]: SIMATIC PCS 7 V9.0 with SP1
try start simatic security controller with repeat settings...
connect your pc to any lan..
rayen_6827
YOU CAN SEE THIS POST
I PUT PICTURE IN PAGE 2
DO YOU CAN HELP
https://support.industry.siemens.com/tf ... ageSize=10
DO YOU CAN HELP
uninstall sql,
delete sql data from: %USERPROFILE%\AppData\Local\Microsoft\Microsoft SQL Server Data\
try install sql...
try install sql...
rayen_6827
THANKS
I INSTALL NEW WINDOWS AND NO SQL IN WINDOWS.
rayen_6827
No anybody for answers?
