InduSoft Web Studio v8.1 SP3
HooK
Post by HooK »
I've made an updated keygen for InduSoft Web Studio v8.1 SP3:
Download App (1.2GB) from site:
hxxp://download.indusoft.com/81.3.0/IWS81.3.0.zip
Change hxxp to http!
Keygen + Proper Instructions:
https://mega.nz/#!GxtBzSSB!tA0HLpYkrhVpz1aQMTG8nvRRhAg-dz1F0YEclKhdH7A
Pass:
Just4testing!!!
Enjoy! 8-)
josgoumix
Re: InduSoft Web Studio v8.1 SP3
Post by josgoumix »
Please I need de password of InduSoft Web Studio v8.1 SP3.rar.
Thanks!!
monty_burns_007
Post by monty_burns_007 »
password: Just4testing!!!
edit: thx HooK , working fine :-)
dj1178
Post by dj1178 »
How many potions if using 9993C
jlfsodre
Post by jlfsodre »
Hello Guys,
The keygen was removed, would someone post again. Please.
juanmemo
Post by juanmemo »
Keygen removed :cry:
Kerohuixco
Post by Kerohuixco »
Please somebody upload keygen, crack of Indusoft Web Studio V8.3 SP3
MaCK1e
Post by MaCK1e »
(wow) Keygen Removed, can you re upload? Please (oo) (dlink)
polzovatel12
Post by polzovatel12 »
Please
Please
anisur692005
Re: InduSoft Web Studio v8.0 crack for win7 , 64 bit
Post by anisur692005 »
Could you please send crack file to my mail anisur692005@yahoo.com
socramsss
Post by socramsss »
Toms
Post by Toms »
Thanks for sharing!
(tyou) (tyou) (tyou) (tyou) (tyou) (tyou)
fredguy
Post by fredguy »
(tyou) (gpost)
Zeljko82
Post by Zeljko82 »
Can you please reupload link.
When i download this one it tell's me that archive damaged.
(dlink)
Fabricio_
Post by Fabricio_ »
Please, anyone can be upload a keygen (softkey) for IWS v8.1 o send me in mail fabriciofper@bol.com.br
bilalayub
Post by bilalayub »
Dear Please upload keygen for Windows CE (CEView)...
Thanks in advance! (gpost)
ahmed229
Post by ahmed229 »
can u upload crack again please
masoga
Post by masoga »
Please, anyone can be upload a keygen for IWS v8.1 SP3 or send me in mail kho.systems@gmail.com
socramsss
Post by socramsss »
ahmed229
Post by ahmed229 »
hello
thank u so much
i was have win 7 64bit and its was work on it
and now i change to win 10 64bit but after install its not open i do not know why
can u help me please
and its not show me anything .its not open without any msg
AND ITS show me runtime only . i type 9999 3c
fredguy
Post by fredguy »
This works up to InduSoft Web Studio v8.1 SP4.
Any one has anything for InduSoft Web Studio v8.1 SP5?
(tyou)
mahmoud31
Post by mahmoud31 »
plz can you upload the crack again because the file is damage (tyou)
Schtiel
Post by Schtiel »
bilalayub wrote: Tue Dec 31, 2019 9:12 pm Dear Please upload keygen for Windows CE (CEView)...
Post your code
Schtiel
Post by Schtiel »
jandonian
Post by jandonian »
fredguy wrote: Mon Jun 08, 2020 4:26 am This works up to InduSoft Web Studio v8.1 SP4.
(tyou)
Method For SP5 working installation:
First install V8.1 SP4 and fix it using by replacing the cracked files and then running the licensing file. Second install V8.1 SP5 in the same folder you installed SP4. You will have a working V8.1 SP5.
Jandonian
HooK
Post by HooK »
Getting v8.1 SP5 to work is no problem. I am looking for someone to confirm if v2020 is working...
If you got v2020 to fully work, please let me know...
Thanks,
-HooK
Toms
Post by Toms »
Hi Hook
InduSoft V2020 software please share with me
Thanks,
HooK
Post by HooK »
Toms
Post by Toms »
(suc) (tyou) (tyou) (tyou) (tyou) (tyou) (tyou) (suc)
fredguy
Post by fredguy »
Thanks Jandonian! It works great with this method. (tyou)
jandonian
Post by jandonian »
Method for Installation of Indusoft V2020 using SP4 licensing method
Step-1: Install Indusoft 8.1 SP4
Step-2: Register it using the usual method (replacement of three files and registering 9999 3C method)
Step-3: Install Indusoft 2020 in the same folder you installed V8.1 SP4 <------ Important
Step-4: Run the program it will give the license error (no Problem)
Step-5: In the instlled folder (in my case C:\Program Files (x86)\InduSoft Web Studio v8.1\Bin) open "Programs Setting.ini" and change Version from 2020 to 8.1 and ServicePack from 4 to 6 under [Install] as shown below:
[Install]
UnisoftPath=
Version=8.1 <----------
Language=EN
DemoMode=FALSE
TestCompatibility=1
ServicePack=6 <------------ just to differentiate between SP4 & 2020
BuildNumber=3801.1911.0501.0000
betaName=
Patch=0
Run the program it will work but when you will check the About menu it will show version 8.1 SP6.
Actually, what we are doing here is using the registration of 8.1 and then making the v2020 think it is version 8.1 by changing "Programs Setting.ini" file.
Please provide feedback if it works for you or not. If it does not work I will provide another method (a lengthy one that require installation of v8.1 SP4 and then v2020 and v2020 again)
Regards,
Jandonian
mahardika
Post by mahardika »
v2020 not recognize valid license when opening application from previous version, so will run in demo mode 40 hours
Sauki
Post by Sauki »
Hii all
im new here , thanks for being sharing great to be apart of this forum
best regards
sauki :D
josep1986
Post by josep1986 »
Thank you jandonian, it work very well
robcioj
Post by robcioj »
I have problem to generate Site Code - Register - Cannot Generate Site Code - anyone had this problem ?? Running as admin doesnt help.
engahmed
Post by engahmed »
Hello
I hope you are doing well.
can you tell me how do the step 2? and what's registering 9999 3C method and how can i do it?
and please share the crack again the file is damage
thanks in advance
jandonian wrote: Sat Aug 01, 2020 7:25 am Method for Installation of Indusoft V2020 using SP4 licensing method
[Install]
UnisoftPath=
Language=EN
DemoMode=FALSE
TestCompatibility=1
betaName=
Patch=0
Regards,
Jandonian
cent
Post by cent »
Hello Jandonian,
First I'd like to thank you for the post, I followed all steps as listed however, I can't save after updating the "Programs Setting.ini" as instructed the file is restricted and an error pop up that I don't have the permission to open the file that I should see the owner of the file or an admin. Kindly advice further on what next is needed to do.
Thanks in advance.
cent
Post by cent »
Hello All,
So, I was able to use notepad++ to save the Program settings file as administrator. But the new problem is that runtime screen is not working. I can't view the project I created on the Demo project runs. I don't know if anyone can advice me on the fix or do i need to downgrade back to 8.1 SP4 ?
xiexunwei
Post by xiexunwei »
Hi, jandonian
the <SP4 licensing>files please share with me
thanks in advance
[Install]
UnisoftPath=
Language=EN
DemoMode=FALSE
TestCompatibility=1
betaName=
Patch=0
Regards,
Jandonian
jandonian
Post by jandonian »
Link for the crack for SP3 / SP4 is
https://drive.google.com/file/d/1iw-mVS ... sp=sharing
Password of the file is Just4testing!!!
jandonian
eggwong
Post by eggwong »
Hi, May i know , how can i transfer license for a raspbery pi ? or linux system. Thanks
NobbyPLC
Post by NobbyPLC »
Thanks, HooK, jandonian, for the keygen & Info,
I thought I’d share some information I found about the licencing of Web Studio 8.1 & earlier revisions.
The license is linked to the Ethernet card MAC address & “Studio Manager.exe” full path. When you run the keygen it creates a register setting in the following location:
32Bit Systems
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{7E81D9FD-3656-4FA8-88EC-2437CE593EAE}\02]
64Bit Systems
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{7E81D9FD-3656-4FA8-88EC-2437CE593EAE}\02]
DATA:
MAC Address Key (yours will be different)
"3FC2EE390D59A0EFB5EAF91E36E948D02D7CE981B26F25E3748ED7611A11D1F6 34"
NAME:
I’ll try and explain the Name as best I can.
32Bit Systems Name:
"xe.eeragan MioudStn\Bi1\8. vioudStb Wet ofuSnd\Iesil Famgrro\PC:"
64Bit Systems Name:
"xe.eeragan MioudStn\Bi1\8. vioudStb Wet ofuSnd\I6)x8 (esil Famgrro\PC:”
This is the "Studio Managers.exe" name and full path backward, 2 letters at a time. Starting from the end
First two = “C:”, next “\P”, next “ro”, next “gr”, next “am”, etc
So "xe.eeragan MioudStn\Bi1\8. vioudStb Wet ofuSnd\I6)x8 (esil Famgrro\PC:"
= "C:\Program Files (x86)\InduSoft Web Studio v8.1\Bin\Studio Manager.exe"
                              etc <---  ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^
                                        F E D C B A 9 8 7 6 5 4 3 2 1
^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ^ ---> etc
1 2 3 4 5 6 7 8 9 A B C D E F
This works for older versions too with the same key.
Web Studio 7.1 =
"xe.eeragan MioudStn\Bi1\7. vioudStb Wet ofuSnd\I6)x8 (esil Famgrro\PC:"
Install on another PC with reg key:
1. Find MAC address of desired PC (cmd “getmac”).
2. Create / Run VMWare running windows.
3. Change MAC address to desired PCs (Setting, Network Adapter, Advanced, MAC Address)
4. Install Web Studio
5. Copy & register with Keygen & make sure it works.
6. Export Registry settings
7. Run reg8.1.reg on desired PC & install Web Studio
8. Change to Softkey Licence & press check (if all ok you should see it activated)
Export Reg cmd code:
x32
REG EXPORT HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{7E81D9FD-3656-4FA8-88EC-2437CE593EAE}\02 reg8.1.reg
x64
REG EXPORT HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{7E81D9FD-3656-4FA8-88EC-2437CE593EAE}\02 reg8.1.reg
Example Reg key (x64) for v2020, v8.1, v8.0, v7.1 (DON'T USE ON YOUR SYSTEM it will delete your current activation)
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{7E81D9FD-3656-4FA8-88EC-2437CE593EAE}]
"xe.eeragan MioudStn\\Bi1\\7. vioudStb Wet ofuSnd\\I6)x8 (esil Famgrro\\PC:"="3FC2EE390D59A0EFB5EAF91E36E948D02D7CE981B26F25E3748ED7611A11D1F6 34"
"xe.eeragan MioudStn\\Bi0\\8. vioudStb Wet ofuSnd\\I6)x8 (esil Famgrro\\PC:"="3FC2EE390D59A0EFB5EAF91E36E948D02D7CE981B26F25E3748ED7611A11D1F6 34"
"xe.eeragan MioudStn\\Bi1\\8. vioudStb Wet ofuSnd\\I6)x8 (esil Famgrro\\PC:"="3FC2EE390D59A0EFB5EAF91E36E948D02D7CE981B26F25E3748ED7611A11D1F6 34"
"xe.eeragan MioudStn\\Bi0\\02 2ioudStb Wet ofuSnd\\I6)x8 (esil Famgrro\\PC:"="3FC2EE390D59A0EFB5EAF91E36E948D02D7CE981B26F25E3748ED7611A11D1F6 34"
DATA = "3FC2EE390D59A0EFB5EAF91E36E948D02D7CE981B26F25E3748ED7611A11D1F6 34" = My MAC Address, YOURS WILL BE DIFFERENT..
Example for Web Studio 2020 (x64) With "Programs Setting.ini" changed to v8.1
"xe.eeragan MioudStn\Bi0\02 2ioudStb Wet ofuSnd\I6)x8 (esil Famgrro\PC:"
= "C:\Program Files (x86)\InduSoft Web Studio 2020\Bin\Studio Manager.exe"
Hope its understandable.
NobbyPLC
fredguy
Post by fredguy »
Very good explanation.
(tyou) (gpost)
mostafa2000
Post by mostafa2000 »
my dear
i have indusoft web studio v8.1 sp3 = windows 10
i want keygen for engineering + runtime
thanks
MicroPLC1
Post by MicroPLC1 »
Was anyone able to get the 2020 version working?
I am having some trouble, I still get the error about the license.
jandonian
Post by jandonian »
Just make changes in Program Settings.ini
[Install]
UnisoftPath=
Language=EN
DemoMode=FALSE
TestCompatibility=1
ServicePack=2020 <--------
BuildNumber=4101.2101.1801.0000
betaName=
Patch=0
MAKERKAOS1
Post by MAKERKAOS1 »
i install v8.1 sp4 and copied the 3 files from the crack but when I run the studio manager it tells me license not found,
plz help :(
Nidal
Post by Nidal »
MicroPLC1
Post by MicroPLC1 »
Nidal wrote: Wed May 05, 2021 4:10 pm try this link
https://drive.google.com/drive/folders/ ... sp=sharing
It says I need access
Nidal
Post by Nidal »
