Greeting,
There is one Software-based solution for position-controlled tasks.
Easy Motion Control (TIA Portal)
Applications include approaching absolute positions or relative traversing, as well as simple gearbox synchronism, both with linear and rotary axes.
Easy Motion Control is the obvious choice when 1 to 5 axes per machine are to be traversed
Free choice of drives (except stepper motors)
Different interface modules can be used for encoder acquisition and set point output, depending on the application.
Input drivers for position acquisition for
CPU 314C
PROFIBUS DP absolute encoder
Universal drivers for any interface modules
Output drivers for controlling the drive for
CPU 314C
MICROMASTER 4 over PROFIBUS DP
Universal driver
Is it suitable solution for following Device & Network...??
1. G120 CU230P-2 DP
2. Danfoss Bauer BS02-34H gear motor n1-1350/min n2-127/min 50Hz
3. THALHEIM Baumer ATD3B B14 Y13 12 PB encoder with Profibus
4. CPU 314C PN/DP with KTP900 using TIA V15
Regard’s
MS
Easy Motion Control S7-300 TIA Portal V15
sarfraz_wnv
