XLReporter
Lucky_Man
XLReporter
Anyone have XLReporter with license? please share me
sachinmamidwar
Re: XLReporter
IS THERE ANY WHO CAN GIVE SERIAL KEY OR KEYGENERATOR FOR XLREPORTER
jandonian
Re: XLReporter
XLReporter v14.41 by Sytech
There you go, medicine is included. File Password: lavteam
https://drive.google.com/file/d/1UCMbNe ... sp=sharing
Enjoy!
Jandonian
Enjoy!
Jandonian
mech962784
Re: XLReporter
Hi jandonian ,
do you have crack for the latest version V15.01 ?
jandonian
Re: XLReporter
Here is the link for XLReporter v15.01 (Installer + Medicine)
https://drive.google.com/file/d/1f349rI ... sp=sharing
Version 15.01
New Features
HMS Ewon DataMailbox
As a security measure, HMS has deprecated user/password authentication for the Data Mailbox API (DMWEB) and now only allows token-based authentication. The Ewon DataMailbox connector has been updated to support this change. Existing XLReporter applications using this connector must be updated to version 15.01, and the connector settings must be modified to use token authentication.
New Connectors
Emerson Automation Solutions
The DeltaV Continuous Historian (OPC UA HA) connector is available to retrieve both raw and summary data from the DeltaV Continuous Historian using the OPC UA HA server.
OPC UA HA
A general OPC UA HA connector is available to retrieve historical data (both raw and summary) from any OPC UA HA server.
Schneider Electric
The EcoStruxure Geo SCADA Expert Alarms and Events connector is available to retrieve alarm and event records from Geo SCADA using the Geo SCADA OLE DB provider.
Version 15.0
New Features
Stacked Reports
Stacked Reports are a new dimension of reporting by “stacking” sub reports. By specifying a few basic settings, the Stack Wizard produces a multi-dimensional template ready for reporting and dashboards. Common uses of stacked reports are:
A report showing multiple batches with each batch showing its individual lots.
A process cycle report showing the cycle performed over stages e.g., clean in place (CIP) for first rinse, caustic wash, sanitize and drain.
A product routing report where the product is produced using a selection of assets e.g., a product basket over a selection of dipping stations.
A process summary report on a selection of assets e.g., OEE over a set of machines.
The foundation of stacked reports is a database table that provides the process conditions that determine the stacking process. An example of such as database table is the XLReporter Event Frame database.
Event Library
Event Frames capture the timestamps of two events in the process (from live data) along with other process data. They are commonly used to represent the time frame of discrete processes such as batching times and machine cycles.
Event Frames can be stored to a database in which case they can be used as the time basis for discrete and stacked reports.
Support for the following functionality is provided:
Integration into the Template Library as an alternative method of selecting the report time frame.
Integration with Stacked Reports to easily provide drill-down discrete reports.
Browse-ability across the product wherever variables are supported.
Template Library
Naming Convention and Schedule
When using the template library to create a scheduled template, the naming convention and schedule settings for the template are exposed in the library so they can be edited directly before the template is created.
Event Frames
The template library has been updated with a new Reporting Method: On-Demand from Event Frames. Prior to this version, a template library configured for On-Demand would typically allow the user to select start and end times using a calendar control.
This new method presents a user with a list of Event Frames, e.g., a list of batch names, and automatically sets the start and end of the report based on the user’s selection.
Variables
New variable types provide events to trigger a report and new mechanisms for components to share information:
Memory Variables
Memory Variables provide fast read/write of system information, numbers, and text and remain permanent until they are overwritten by a new value. They are used as a method convenient for passing information between components of the product as well as triggers in the Scheduler. When used as triggers, a worker template can monitor the historian for conditions to set the variable value using a Management export function.
System Variables
System Variables monitor system and XLReporter performance. They can be used as trigger events in the scheduler e.g., send an email whenever an error occurs on a reporting action.
Action Lists
In previous versions, every Scheduler Action would need to be specified as separate lines in the scheduler. Action Lists group a set of actions and have them performed on a single Condition using the new Update Action List. An action list builder is provided to specify the list of actions. This replaces Schedule Scripts.
Scheduler Action Delay
Action Delay is added for the update Actions such as UpdateWorksheet. This delay is useful when the production of report needs to be delayed to allow the data source complete before it is read.
Data Entry Form Filter
Custom Filters have been added to data entry forms that custom what is displayed when the form is opened and what is stored to the database when the form is saved. The filter is specified in user-configurable SQL syntax.
Email and SMS
Support for blind carbon copy (BCC) is added in the recipient list.
Data Management
New functions to Data Management:
Copy Sub Report Range
This function expands the scope of what can be copied into the report allowing for more dynamic, richly formatted end results.
Square Range
This function normalizes a table of discrete values to improve the appearance of discrete (1/0) data on trend charts.
TransForm Range
This function improves the appearance of summary data returned from historians and databases by displaying the information in a two-dimensional table where each dimension is user specified.
Result from Template
This function allows users to store their reporting or business logic in a workbook external to their templates and use this function to retrieve results. This approach makes the management of business rules in a central document, keeping reports displaying only results.
Data Export to Variables List
This function provides the tools for exporting to a large set of variables from a template.
Status Logs
The Status Logs are used to hold reporting action history. More detailed information is provided in error messages.
Task Monitor
More detailed information is provided for diagnosing runtime performance issues.
Database Manager
Database Manager has been expanded to perform additional database functions such as creating, editing, and populating database tables. Indexing can also be added to improve the runtime performance of data retrieval.
New Connectors
OPCUA
An improved OPCUA connector for retrieving process data using a more comprehensive set of authentication and encryption techniques.
Win-911
The WIN-911 data connector is used to interface with the database managed by the WIN-911 alarm notification system. Templates have been added to the template library to give WIN-911 users “out of box” feedback on the performance of the alarm notification system.
Version 15.01
New Features
New Connectors
OPC UA HA
Schneider Electric
Version 15.0
New Features
Stacked Reports
Event Library
Template Library
Event Frames
Variables
Memory Variables
System Variables
Action Lists
Email and SMS
Data Management
Square Range
TransForm Range
Status Logs
Task Monitor
Database Manager
New Connectors
OPCUA
Win-911
sachinmamidwar
Re: XLReporter
Do u have medicine of XL reporter 16.2.
Waiting for reply...
sachinmamidwar
Re: XLReporter
Hi jandonian ,
do you have crack for the latest version V16 ?
