[?]: WinCC MSQL script
Talaaaat
Post by Talaaaat »
Now I want to make a I/O filed in wincc with a string format and I put it into a database
I created an internal tag with text char 16 and link it to the I/O filed and the output of this I/O field is string
I tested the link between the Wincc and the database and it is worked and recording another data types of real data format
But I tried to send the field with the string data type, it didn't work
The database column which I created was with nvarchar
Please check attached script of the button, can anybody help me to check where is the error
Sub OnLButtonDown(ByVal Item, ByVal Flags, ByVal x, ByVal y)
Dim objConnection
Dim strConnectionString
Dim teto
Dim tetoo
Dim tetooo
Dim tetoooo
Dim strSQL
Dim objCommand
strConnectionString = "Provider=MSDASQL;DSN=Demo;UID=;PWD=;"
teto = HMIRuntime.Tags("nitro").Read
tetoo = HMIRuntime.Tags("watter").Read
tetooo = HMIRuntime.Tags("elec").Read
tetooo = HMIRuntime.Tags("delay").Read
strSQL = "INSERT INTO Table_1 (nit, water, elect,delay) VALUES (" & teto & "," & tetoo & "," & tetooo & "," & tetoooo & ");"
Set objConnection = CreateObject("ADODB.Connection")
objConnection.ConnectionString = strConnectionString
objConnection.Open
Set objCommand = CreateObject("ADODB.Command")
With objCommand
.ActiveConnection = objConnection
.CommandText = strSQL
End With
objCommand.Execute
Set objCommand = Nothing
objConnection.Close
Set objConnection = Nothing
End Sub
yaqui
Re: [?]: WinCC MSQL script
Post by yaqui »
If you are working with SQL Server your string must be like this:
string : ' " & varString & " '
number: " & varNumber & "
strSQL = "INSERT INTO Table_1 (nit, water, elect,delay) VALUES ('" & teto & "','" & tetoo & "','" & tetooo & "','" & tetoooo & "');"
Rex2701
Post by Rex2701 »
Talaaaat wrote:Please check attached script of the button, can anybody help me to check where is the error
You read two tags into the same variable:
