Hi! Controllers PLC Mitsubishi series Q02 Possible through a program GX Works2(3) on the fly (ON Line) edit-edit the program.The task is to add several discrete input signals (there are free inputs ) and process in the existing program by adding several commands and so on. Experience with PLC data and software is not enough, although in principle everything is clear, communication with the controller via RS232 is. In a manual on this saw link what editing is possible,but in that it does not see the Windows icons...or it should be done only through the Developer...???
Sincerely, Defo
PLC Mitsubishi Q02 & Works
defo2004
Re: PLC Mitsubishi Q02 & Works
The problem is solved...helped user manual...
