Difference between RS232, RS485 , RS422
другие контроллеры
zubair136
Post by zubair136 »
i am new in plc programming . i know the basics difference between the rs232, rs422, rs485. but i am little bit confused in it. so i have the following question regarding these terms.
1. can these protocols communicate with each other i mean rs232 can communicate with rs422 or rs485 and same.
2. my plc has port rs422 but i can connect it with my laptop serial port which is rs232 ?
3. what are the main important points that kept in mind during communication or cross communications.
any help will be greatly appreciated.
SE_support
Re: Difference between RS232, RS485 , RS422
Post by SE_support »
zubair136 wrote:i am new in plc programming . i know the basics difference between the rs232, rs422, rs485. but i am little bit confused in it. so i have the following question regarding these terms.
RS232, RS485, RS422 is not a protocol - it's a physical layer.
https://en.wikipedia.org/wiki/RS-485
https://en.wikipedia.org/wiki/RS-232
https://en.wikipedia.org/wiki/RS-422
