Hello Everyone,
I'm trying to communicate a Elipse E3 Software (Brazilian SCADA) with a S7-300 CPU using a CP5622 PCI card mounted in an IPC Siemens SImatic IHM TP 677D. Do somebody has the CP5622 profibus protocol configuration? The Elipse Software uses emulation port to comunicate using Ethernet or COM Port but in this case the CP5622 does not emulate any port it has its own port.
Thanks in advance for your help.
Enrique
CP5622 Profibus Protocol
Re: CP5622 Profibus Protocol
install Simatic Net software
https://www.elipse.com.br/en/produto/elipse-e3/
google: Elipse E3 Software profibus
see elipse documentation about Connection to most devices (PLCsInitially, the CP 5612 and CP 5622 modules could be configured with the Simatic Net software version V8.2 + Service Pack 1 under Windows 7 and higher
https://support.industry.siemens.com/cs ... nd-cp-5622
http://kb.elipse.com.br/pt-br/questions/468/KB-19737Connection to most devices (PLCs, remote devices, data hubs) on the market
kiks
Thanks a lot for you hel CoMod
