Hi friends
TIA updater message "unable to connect to the server" appears. I have antivirus and firewall disabled. The result is the same.
Does anyone have any idea?
Regards.
[?+]: Tia Portal Updater not work
emos
anorexia
Re: Tia Portal Updater
company, router policy can block it also. Norton intelligent file protection also blocks it.
emos
I tried home and mobile phone use internet connection, but same problem.anorexia wrote:company, router policy can block it also. Norton intelligent file protection also blocks it.
emos
Simko
Re: [?]: Tia Portal Updater not work
Start Tia portal updater as Administrator (Run As Administrator).
emos
I tried, nok.Simko wrote:Start Tia portal updater as Administrator (Run As Administrator).
emos
my makeshift
solution at below link
TIA Updater Corporate Configuration Tool
https://support.industry.siemens.com/cs ... 0&lc=en-US
Answers to FAQs
- Faq & Info
Re: [?+]: Tia Portal Updater not work
for correction of this problem install TIA Administrator from here : https://support.industry.siemens.com/cs ... iew/114358
