Hello!
Is PLCSIM Advanced capable of communicating with a Remote IO? Reading entries and Writing in the saida?
If so, how should I do it? The Remote that was configured in the project, in the simulation, seems to be simulated as well as a CPU.
This function would be useful for testing communication with the remote and commissioning remote IOs without the CPU.
Thank you!
PLCSIM Advanced + IM155-6PN ST
Re: PLCSIM Advanced + IM155-6PN ST
Version of TIA Portal and PLCSIM Advanced ?
PLCSIM v14 work with ET200* station i*.*= i*.*:P
PLCSIM v15 have bug adressing i*.*<> i*.*:P
heracliolmj
TIA Portal V14
PLCSIM Advanced V1.0 SP1.
Try TIA Portal V14 SP1/15heracliolmj wrote:TIA Portal V14
and S7-PLCSIM Advanced V2.0
https://support.industry.siemens.com/cs ... anced-v2-0
heracliolmj
I made an update. But I can not work on the outputs of the remote IO. If you have not understood, but the Remote IO is powered on, can the PLCSIM communicate with the hardware?
you want connect simulation to REAL Hardware how software PLC WinAC ?heracliolmj wrote:I made an update. But I can not work on the outputs of the remote IO.
software PLC WinAC RTX ===> CPU 1507S Software Controller
https://support.industry.siemens.com/cs ... /109756778
