I have a problem with TIA portal V15 upd2.
When go PC to screensaver (and lock down, turn off display) PC freeze (stop working). Then PC need hard restart.
System is HP Zbook 15u G4 with Windows 10 pro 1703 and updated to last versions..
Anyone have similar problem?
Thank you.
Jernej
Tia Portal V15 freeze system
Re: Tia Portal V15 freeze system
Intel Core i7 8550U, 4 Core, 1.8 GHz, 16 GB DDR4, SSD 512 GB ....HP Zbook 15u G4
freeze ?
Antivirus ?
but HP always add
https://support.industry.siemens.com/cs ... ankingDesc
What should you watch out for when installing WinCC flexible 2008 SP3 or WinCC V11 SP2 on an HP notebook?
https://support.industry.siemens.com/cs ... t/58217334
but MS always add
Which Microsoft Updates have been tested for compatibility with SIMATIC PCS 7? https://support.industry.siemens.com/cs ... t/18490004
Simko
Yes, freeze.
Sistem is i7-7500U - 2 core, 16GB ram, 512gb ssd
Last week uninstall antivirus, now it works better.
