Hi guys, i am beginner using Eplan. During created my first project, i am not able to to open any symbol (inside Eplan interface, in the Project Data tab, selecting symbols,it's empty. For what i have seen Eplan data are stored by default in folder "ProgramData\EPLAN\O_Data" where they are located two(2) folders "Electric P8 Data" and "Platform Data", inside of which are the data for symbols, plotframes, templates. I have find another folder created EPLAN, which is located "Users\Public\EPLAN\Data\Administration\Company name" which is empty. For what i have understand i have to do some modifications, change/select directories under Option tab in Setting menu (which contain Projects, Users, Workstation, Company) or/and under Utilities tab, Master data menu (which contain Symbol library, symbol, Plot Frame, Form and synchronize current project.
   Can somebody explain me how to proceed, to setting up Eplan correctly. Do i have to copy some folders to specific locations or just change/ select directories inside EPLAN interface and exactly from where? I have done some research before ask, but i didn't understand what exactly to do
   Thank you in advance
						Eplan Electric P8 2.6 symbol library could not be found
				TheoPap
				Albundy0124
Re: Eplan Electric P8 2.6 symbol library could not be found
I think that should show the symbols u have used already in the project.
If the project is empty, that tab should be empty aswell.
To insert symbols or parts, go to insert menu, or press insert or alt+insert shortkeys.
				FRD66
Hi, could you solve this problem?
				alwaysdie1900
Office version 2013 and younger will solve the problem.
Versions of 2013 and above cannot open data.
