hello,
I have searched the forum but could not find a link to the conversion tool from S7-200 to S7-1200. To install in TIA Portal Basic 10.5.
Can anyone please provide me the program?
thanks,
Bruno
						Convert tool S7-200 to S7-1200
				BLima
				cyanid-e
Re: Convert tool S7-200 to S7-1200
http://www1.siemens.cz/ad/current/index ... d_software
https://support.industry.siemens.com/cs ... to-s7-1200
http://www1.siemens.cz/ad/current/index.php?ctxnh=5dc8474325&ctxp=download_softwareCode: Select all
https://support.industry.siemens.com/cs/document/39637591/making-the-transition-from-s7-200-to-s7-1200-
				fatihgns
I uploaded converting tool file in Siemens forum.
https://support.industry.siemens.com/fo ... tId=181339
 https://disk.yandex.ru/d/7-0vLWrl33nnou ("S7-200_to_S7-1200_Program_Converter" folder)
You can install it over Tia V11 SP2.
After installing converting tool, You will see "Convert S7 200 Project" below Project>Migrate project.
Have a good day.
Fatih,
https://support.industry.siemens.com/forum/tr/en/postattachments/download/?attachmentId=181339You can install it over Tia V11 SP2.
Have a good day.
Fatih,
				Henry_25s
Could you help me with the download links needed to perform this conversion from s7-200 to s7-1200, please? How should I proceed step by step to convert from microwin to tia portal?
