Hi dears, I've got a EPlan 2.7v (with crack) at Internet and it's work well, but I can't get material ou devices by data portal eplan .
Someone give tips how can I do it , please ?
data portal
chusebizen
Re: data portal
Dear Friend.
You should first read a little bit in the forum
, because it is easy to find the answer to your question.
Without a legal copy of Eplan, including maintenance contract, there is no way to access Data Portal.
Searching a little bit more in the forum, there is a post where you can find a still version of the data portal as individual edz files to be imported. It is not comfortable, but it's the best you will get...
Good luck...
Good luck...
