I have a machine with AB control logix 5550 cpu and a panel view 2711p.
I need to connect a pc to be able to monitor, whatever it is in the existing panel view.
What software do i need (configuration and run time)? is it factory talk view machine edition?
I have the panel view file, is it possible to just use it in the pc?
Need help with software selection
Re: Need help with software selection
There are "Factory talk View SE (site edition)" and "Factorytalk View ME (machine edition)" and FT View SE is used when your system is operated on PC (run application on PC) and FT view ME is used when you use panel view to operated the system.
As my understanding you cannot migrate FT View ME to SE ( I mean directly convert).
Anyway to can search for this program for more information.
