I'm working on the project, where my customer requires an AB HMI to control certain functions of the machine equipped with Siemens S7-1200 and TP700 Comfort.  I'm trying to do as minimal programming on the AB end, thus I would like to simply access Siemens HMI screens with the VNC client.  Siemens Comfort panel has the Sm@rtServer (a VNC server) enabled and running, and from what I understand, AB Panel View Plus 7 (10.4" T10C21) has the VNC client installed.
My question are:
1. Can VNC client be open from the AB runtime?
2. If answer to my previous question is yes, then is it possible to define connection parameters (IP & password) to the Siemens VNC server be configured without the need of typing IP address and password each time connection is being started?  I would like this to be implemented possibly with single click of a button, so the operator doesn't have to type IP address and password each time he tries to connect?
Thank you.
Olgierd
						Panel View +7 HMI access Siemens Comfort panel - VNC client?
				AdrianSos666
