Salut
Est ce que c'est possible installé le Simatic Manager 5.5 et le TIA PORTAL sur le même PC ????
Merciiiiiiiiii
Simatic et TIA Portal
KDkant
Re: Simatic et TIA Portal compatible
I use STEP 7 Professional V14 and STEP 7 Professional 2010 (=v5.5) in one PC with Windows 7
it compatible
https://support.industry.siemens.com/cs ... ional-2017
it compatible
The Field PG M5 software pre-installation STEP 7 Professional 2017 contains the following software packages:
STEP 7 Professional V14 SP1
STEP 7 Professional V13 SP2
WinCC Advanced V14 SP1
Startdrive V14 SP1
Startdrive V13 SP2
PLCSIM V14 SP1
PLCSIM V13 SP2
STEP 7 Professional 2017 (=v5.6) https://support.industry.siemens.com/cs ... /109749362
WinCC flexible Advanced 2008 SP5
Option package: STEP 5
Adnan182
KDkant wrote:I use STEP 7 Professional V14 and STEP 7 Professional 2010 (=v5.5) in one PC with Windows 7
it compatible
Startdrive V14 SP1
Startdrive V13 SP2
PLCSIM V14 SP1
PLCSIM V13 SP2
Thank you very much KDkant
