Eaton Easy PRO Between 6.90 and 6.96 need?
другие контроллеры
Raptor
Post by Raptor »
Hello Dear friends. I need Eaton Easy PRO 6.90 or 6.96 , intelligent relay software. Plase if you have : can you share for we? Please full. (for relays Eaton Easy 200, 400, 500, 700 and 800)
I think Eaton and Moeller are using the same software
Software link:
http://applications.eaton.eu/sdlc?LX=11 ... 74&f3=1185
PLC cable Eaton EASY-USB-CAB 107926
Software
Multi-lingual programming
Hardware selection screen
Simple drag and drop circuit diagram drawing editor
Control circuit configuration tools
Offline simulation
Online Commissioning
Suitable for running under Windows NT SP6, 2000 SP4, XP SP1 and 7 (32/64Bit)
AlekMalek
Re: Eaton Easy PRO Between 6.90 and 6.95 need?
Post by AlekMalek »
I have software for them. And yes, they are programming from the same software. More over ABB controllers also could be programmed with this soft.
h4rdw4re
Post by h4rdw4re »
AlekMalek wrote:I have software for them. And yes, they are programming from the same software. More over ABB controllers also could be programmed with this soft.
Can you share it?
Raptor
Post by Raptor »
if you possible please share it. PM messages or global..
h4rdw4re
Eaton Easy PRO 6.96.5388
Post by h4rdw4re »
Raptor
Re: Eaton Easy PRO Between 6.90 and 6.96 need?
Post by Raptor »
Thank you really..
