AFTER DEAD MEAN PLATE IN FREQUENCE DRIVER WE ARE SETUP NEW PLATE.
THEN WE TRY TO CHANGE PARAMETR CURRENT TO 200A WE HAVE NOT CAN CHANGE BECOUSE PROGRAMM GIVED MESSAGE:
- Modbus device returned an exception code 3 (ILLEGAL DATA VALUE: A value contained in the query data field is not an allowable value for the slave.
Perhaps Value outside min--max limits,
Parameter is read-only,
Parameter write not allowed when Drive is running or
Parameter write not allowed when factory macro is selected.
Also check that parameter lock-parameter is not active) while writing register 101
(THEN WE TRY TO CHANGE 18A - OK..20-OK 21- NOK)
WHAT WE MUST DO TO SOLVE THE LIMIT?
ABB DCS 402.0680 CAN NOT CHANGE PARAMETR
zaplatin
Re: ABB DCS 402.0680 CAN NOT CHANGE PARAMETR
на плате был выбран тип привода dcs401 соответственно ток у него 20А макс.zaplatin wrote:AFTER DEAD MEAN PLATE IN FREQUENCE DRIVER WE ARE SETUP NEW PLATE.
C ПУЛЬТА ДЛЯ ПРИВОДА ВЫБИРАЕМ:
MENU-LONG/SHORT-LONG-SET TYPE CODE - 400 (ПАРОЛЬ ИЗ ИНСТРУКЦИИ) - ВЫБИРАЕМ ТИП ДРУГОЙ DCS402.0680 ПЕРЕЗАГРУЖАЕМ ПРИВОД .
ПОСЛЕ ЭТОГО ЛИМИТ ТОКА 1000А
