Monitoring on/off disable - ET 200s CPU / TIA V13 SP1 UPD9
danilo_ops
Post by danilo_ops »
Good evening, sir.
1) Sorry for my English.
2) If you have any topic on this subject, please let me know that I remove this one. I researched a lot and did not find it.
I have an IM 151-8 PN / DP CPU (6ES7 151-8AB01-0AB0) in which there is a program running, but this program is not my own.
I have the A3 Portal SP1 UPD9 installed, I was able to upload and go online, however, I can not monitor (monitoring on / off), the monitoring button is disabled.
What can it be?
http://5cm.ru/view/i7/bqTn.png
http://5cm.ru/view/i7/qLCb.png
http://5cm.ru/view/i7/OkMT.png
Re: Monitoring on/off disable - ET 200s CPU / TIA V13 SP1 UP
Than connecting? Where to connect? What are the connection settings?
Give more information.
danilo_ops
Dfcz wrote:Than connecting? Where to connect? What are the connection settings?
Hi Dfcz.
1) TIA V13 SP1 UPD9
2) CLP IM 151-8 PN / DP CPU (6ES7 151-8AB01-0AB0)
3) Interface: PROFINET_1 - Subnet: PN/IE_1 - Cable: Point-to-point Ethernet through a router - Port: (X1 P1 R)
Does this image help?
If you need anything else, return me.
Дубль два:
Give M O R E information.
danilo_ops
Dfcz wrote:Дубль два:
Connection to the PLC via a Cosy 141 (eWON), Ethernet architecture, local network;
Fixed IP on my PC, on the same PLC layer;
A SIMATIC Micro Memory Card is inserted in the PLC;
There are other devices configured in the PLC network, such as a Siemens HMI and a Kuka Robot;
(sos)
